24 Октября 2026, 04:53:51 *
Автор Тема: Китайцы практически полностью рассекретили Хонду CR-V четвертого поколения !  (Прочитано 16014 раз)
« : 14 Августа 2011, 15:54:23 »
Honda’s next generation CR-V (Code – 2WS) has been spied partially uncovered in China. The exterior demeanor is similar to the concept Honda previewed through a photograph released last month.
The executives sanctioning this model for production aimed at introducing a sporty replacement to the big-winning crossover. With the Civic, the route taken was a slightly conservative/toned down one. But with the CR-V brave concept car trimmings have reached the production spec model.
The extra large front grille caves into the headlamps while the stop lights are Volvo XC60-esque. The slabs on the radiator grille are thick and contoured, while the headlamps are pulled back into the front wings. The side profile is the same as revealed by an AutoBlog.com spy shot followed by an in-house SRK rendering.
There is a slight kink on the rear three quarters while the whole car looks more pointed unlike the currently serving model that is bulbous and rounded at many points.
What we’re still not able to identify is if the CR-V has metamorphosed into a 7 seater for the full family. Under the hood, the next gen CR-V will use a 2.4-liter four-pot petrol engine engine fitted with variable valve timing generating above 150bhp sending drive to either the front axle or all four wheels. Two years into its life, some markets could get a taste of an all-new diesel engine Honda’s developing for some of its compact vehicles.
The interior shots shows clear resemblance to the new Civic. The gear changer has been mounted on an extended dashboard, built using high quality materials, but unlike the Civic, parts adjacent to the driver has not been angled towards his sear in the view of improving ergonomics.
KИТ.
Авто:Honda CR-V III 2,0 акпп
год:2008/09
г.Коломна.
« Ответ #1 : 14 Августа 2011, 22:56:07 »
     Для пуска двигателя кнопочку поставили.
Спереди будут хромированные полоски как на кросстуре. Между сидений появился трансмиссионный тоннель. Пластик салона скорее всего такой-же жёсткий. На панели приборов появилось "экологическое деревце". Исчез верхний бардачок. Зона покоя дворников не обогревается из салона, остаётся надеятся на наличие электроподогрева лобового стекла.
Sanchez
Авто:Honda CR-V III 2.0 EXE
г.Москва - кыев
« Ответ #2 : 15 Августа 2011, 03:17:10 »
Если судить по первой фотографии, возможно в европейской версии будут светодиодные ходовые огни. Веселый Веселый
mag
Авто:CR-V 2.4 Exe Leather
г.Тюмень
« Ответ #3 : 10 Сентября 2011, 15:02:40 »
Заметил: если сравнивать с официальной фотографией, то зеркала не такие как на официальной, больше, как в третьем кузове.
moon175
Авто:Civic 4D МКП 1,8VTEC
г.Ставрополь
« Ответ #4 : 10 Сентября 2011, 22:20:10 »
Так это же они представили концепт, естественно что зеркала в реале будут большие как минимум такие же как на cr-v 3.
k-700
Авто:СR-V. 2.4. GG
« Ответ #5 : 11 Сентября 2011, 22:14:38 »
Странно, что опять показания топлива и температуры стрелочными сделали В замешательстве
Heizmann
Авто:CR-V, 2.0, МКПП
« Ответ #6 : 13 Сентября 2011, 16:26:04 »
Странно, В замешательстве
Смотрим внимательно на боковины, переходы с бамперов на крылья, характерную боксерскую челюсть переднего бампера, форму крыши и даже лыжи под брюхом.
Я, например, отличий от существующей модели не вижу.Соответственно, можно сделать вывод, что Хонда будет выпускать существующую CR-V в Китае, всего-лишь немного подправив внешность и удлиннив задницу под третий ряд сидений.Что мы и видим на картинках с, исключительно, иероглифами.
А новая CR-V будет все-таки совсем другой.
lisarden
Авто:CR-V 2.0 Lifestyle 5AT
г.Люберцы
« Ответ #7 : 18 Сентября 2011, 19:18:57 »
дайте две!
Пол
Авто:CR-V 2,4 EXE Deep Bronze, ну ооочень бежевый салон
« Ответ #8 : 20 Сентября 2011, 17:34:19 »
да уж.. мне нынешняя приборка больше нравится
