19 Ноября 2026, 20:34:04 *
Автор Тема: #Service Bulletins of Honda Cr-v 5 Gen  (Прочитано 5682 раз)
« : 16 Октября 2018, 21:08:06 »
В этой теме, будем выкладывать сервис бюллетени по Honda Cr-v 5 поколения !
__________________________________________________________________________________________
Brakes and Traction Control
NHTSA ID: 10134508
TSB ID: APaS04062018901
Dealer message - american honda motor co., inc. (ahm) is investigating certain 2017-2018 cr-vs with a customer complaint of various warning lights such as the brake system, lane departure, acc & forward collision warning illuminated on the
Electrical and Air Conditioning
NHTSA ID: 10133005
TSB ID: ATS180303
Tech line summary article - got a vehicle with the message requested channel not available covering the siriusxm preset icons? we?re aware of this issue and have it under investigation.
NHTSA ID: 10129331
TSB ID: APaS02142018902
NHTSA ID: 10128892
TSB ID: A18-006
Service bulletin - the acc, lkas, rom, collision mitigation brake system, and brake indicators come on with a otc b2a60-49 (multipurpose camera unit internal electronic failure). an auto high beam problem message may also appear in the mi
NHTSA ID: 10127168
TSB ID: APaS01032018901
Other
NHTSA ID: 10133031
TSB ID: A17100H
Servicenews article - when installing the shipping fuses, never do it with the engine running. if you do, you could wind up with any of these issues: ? with the headlight switch in auto, the auto high beam system indicator won?t come on.
Other
NHTSA ID: 10130040
TSB ID: APaS01112018901
Dealer message - american honda motor co., inc. (ahm) is investigating certain 2017-2018 cr-vs with a customer complaint of the front left and/or right door touching the fender. to fully understand the cause of this condition, ahm would lik
Other
NHTSA ID: 10129423
TSB ID: ATS180104
Tech line summary article - if you get a vehicle in because the browser app isn?t showing up on display audio, there?s nothing that needs fixing. we didn?t include that app in 2018 models. the online owner?s manual reflects this.
Other
NHTSA ID: 10129417
TSB ID: A17100H
Other
NHTSA ID: 10127354
« Ответ #1 : 06 Ноября 2018, 03:01:53 »
* 1.jpg (102.13 Кб, 540x960 - просмотрено 1195 раз.)
* 2.jpg (76.4 Кб, 540x960 - просмотрено 1006 раз.)
* 3.jpg (71.73 Кб, 540x960 - просмотрено 1165 раз.)
* 4.jpg (57.84 Кб, 540x960 - просмотрено 1109 раз.)
* 5.jpg (33.6 Кб, 540x960 - просмотрено 959 раз.)
* 6.jpg (46.49 Кб, 540x960 - просмотрено 978 раз.)
« Ответ #2 : 22 Декабря 2018, 11:49:49 »
* 1.jpg (84.18 Кб, 678x960 - просмотрено 1061 раз.)
* 2.jpg (73.69 Кб, 689x960 - просмотрено 1007 раз.)
* 3.jpg (64.67 Кб, 688x960 - просмотрено 928 раз.)
« Ответ #3 : 17 Мая 2019, 22:47:53 »
* 1.jpg (157.51 Кб, 720x960 - просмотрено 843 раз.)
