03 Мая 2026, 21:04:03 *
Страниц: 1 ... 12 13 [14]   Вниз
Автор Тема: #Панель приборов honda cr-v 2 (замена на оптитрон)  (Прочитано 181608 раз)
zabor
Авто:Honda CR-V II USA АКПП
г.Петрозаводск Карелия
« Ответ #195 : 16 Мая 2020, 12:36:44 »
Меняется, хоть на японский, хоть на европейский....
sega1979
Авто:Honda CR-V 2,4 .АКПП, RD6 американка
г.Петропавловск
« Ответ #196 : 11 Июня 2020, 12:52:36 »
ДД! А на японку распиновка у кого нить есть или там одинаковая?
sergeuERJ
Авто:Honda CR-V 2 двс 2.4 автомат ..
г.Шахты Ростовская обл.
« Ответ #197 : 13 Июля 2020, 16:12:25 »
Всем привет что то я не пойму только у меня индикатор дальнего света через минус работает ?
ma_ko
Авто:Honda CR-V 2.4 EX
г.Варшава
« Ответ #198 : 20 Мая 2023, 14:27:44 »
Hello, sorry for the English language but I'm from another country and I don't know Russian Грустный I wanted to put a new european cluster into my 2006 CR-V EX from USA. I connected most of the pinouts (many thanks for all the schematics) but for now I have several questions/problems:
1. High beam indicator stays on when the car is off. When I turn the ignition on, the indicator is off and turns on when i start high beams. So it works as expected but why it stays on? even when the car is locked and i'm away? Looks like it's getting power after turning the ignition OFF
2. Interior light (a/c backlight and other buttons backlight) doesn't work. Did i forget about something? I havent connected fuse#9 (what is it?) because there is no fuse#9 in the new cluster schematic.
3. It turned off VSA light by connecting ground but is there another way for it to work? My car has VSA and I would like the indicator to work. If i connect it as show on the schematic the VSA is on constantly and doesn't disappear after starting the car (it does on the old cluster)
4. What are fuse 15 and fuse 2?
Apart from that everything works, even instantenous fuel consumption  Афро
I know it's been 3 years since the last reply but maybe someone worked on it and still remember it. Many thanks for the answers
Здравствуйте, извините за английский язык, но я из другой страны и не знаю русского Грустный Я хотел поставить новый европейский кластер в мой 2006 CR-V EX из США. Я подключил большую часть распиновки (большое спасибо за все схемы), но пока у меня есть несколько вопросов/проблем:
1. Индикатор дальнего света остается включенным, когда машина выключена. Когда я включаю зажигание, индикатор выключен и включается, когда я включаю дальний свет. Так что все работает, как ожидалось, но почему он остается включенным, даже когда машина заперта и меня нет дома? Похоже, что он получает питание после выключения зажигания.
2. Не работает подсветка салона (подсветка кондиционера и других кнопок). Я что-то забыл? Я не подключил предохранитель №9 (что это?), потому что в схеме нового блока нет предохранителя №9.
3. Он отключил свет VSA, подключив землю, но есть ли другой способ, чтобы он работал? В моем автомобиле установлена система VSA, и я хотел бы, чтобы индикатор работал. Если я подключу его, как показано на схеме, VSA горит постоянно и не исчезает после запуска автомобиля (как на старом кластере).
4. Что такое предохранитель 15 и предохранитель 2?
Кроме этого все работает, даже мгновенный расход топлива Афро
Я знаю, что прошло 3 года с момента последнего ответа, но может кто-то работал с этим и еще помнит. Большое спасибо за ответы
Переведено с помощью DeepL
ma_ko
г.Варшава
« Ответ #199 : 26 Мая 2023, 13:10:54 »
Извините за повторное сообщение, но я решил большинство проблем. Осталось только две. VSA все еще не работает. Я отключил ее. Индикатор SRS горит. Возможно, потому что я не подключил резисторы и диод, но я не знаю как. Похоже, что схема подключения отсутствует. Только маленькая фотография. Но я не могу понять, какого размера должны быть резисторы и куда их подключать. У меня европейский кластер, и в нем нет индикатора отключения боковых подушек безопасности. Спасибо
vadim838
Авто:Honda CR-V 2 2.4 механика
г.Могилев
« Ответ #200 : 27 Мая 2025, 15:17:57 »
Подскажите. На приборку у срв 2 поколения  отдельный датчик температуры охл жидкости или один тот же что и на мозги дает показания?
Вопрос как-то решился?
Страниц: 1 ... 12 13 [14]   Вверх
